Nintendo 3DS SD Board Replacement
  1. Nintendo 3DS SD Board Replacement, Loosen the rear screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS SD Board Replacement, Remove the rear cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS SD Board Replacement, Remove the rear cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS SD Board Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS SD Board Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS SD Board Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS SD Board Replacement, Lower Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. Nintendo 3DS SD Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS SD Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS SD Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS SD Board Replacement, SD Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  7. Nintendo 3DS SD Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS SD Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The connector for the SD board sits underneath the Circle Pad ribbon cable.
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  8. Nintendo 3DS SD Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS SD Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS SD Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
    At this point it's a lot harder to get the SD card split from the heat shield under it. The epoxy is pretty adhesive. Because of this I bent the heat shield and it broke from the solder joints on the internal side of the SD reader. I'm hoping a quick retouch of the solder will adhere the shield back above the processor without any additional damage. However, that won't be until tomorrow when I check / test it. I'm also awaiting the part to arrive which should be within the week.
    Ben Kevan - crwdns2934203:0crwdne2934203:0
    I finally received my SD Card Reader (which was mis-routed twice by USPS). I the SD Card sits on top of the head guard fine, but without the adhesive it will come up slightly. This was minimized when putting the 2 screws back in.
    The assembly was simple and unlike many others, I had 0 stripped screws.
    I am happy to report that after putting it all back together the issue was resolved by the $7 replacement part.
    Ben Kevan -
    Where can I buy the SD card reader? Is it a special kind of will any SD card reader work?
    Thomas Stodghill - crwdns2934203:0crwdne2934203:0
    Would this work for my problem? My problem isn't that it can't read the SD card it's just that the thing the pops out the SD card when you push on it is broken and thus I can't take out my SD card which I want to do to move data from it to my PC. Would this method still work? I don't want to have to pay Nintendo to fix it.
    penguin1000 - crwdns2934203:0crwdne2934203:0
    Yes this would resolve your problem as well. The spring mechanism is part of the metal can of the sd card reader.
    Marco -
    What kind of adhesive tape is under the SD card? Does it need replacing?
    visionquest - crwdns2934203:0crwdne2934203:0
crwdns2935229:022crwdne2935229:0
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
153 500 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2947412:012crwdne2947412:0
Where can i purchase the sd card board replacement part? Does amazon carry them?
Jen - crwdns2934203:0crwdne2934203:0
You can usually find them on ebay to around $3 to $6 dollars (non oem and oem)
David Vokas -
Is there a way to do this with the older 3ds xl version? I didn't see any screws holding the sd board in when I opened it up.
NickySeley - crwdns2934203:0crwdne2934203:0
Would this work for my problem? My problem is that the SD Card won't stay in, it just pops back out. Would this method still work? I'm not that experienced or knowledgeable about fixing these sort of things, so I'm not sure if the spring is part of it or not, lol. Also, where could I buy an SD Card board replacement part for cheap in Canada?
Caitlin Lumsden - crwdns2934203:0crwdne2934203:0
Usually that is the locking mechanism, you can replace the SD card slot for around $6 or $3 if you buy the non oem part.
David Vokas -
Be careful when removing the SD Card Assembly, as lifting too hard will bend the metal plate it sits upon.
Ricky Gonce - crwdns2934203:0crwdne2934203:0
Could this cause bads reads. My 3ds wont detect my sd cards any more.
Matthew Chometa -
The silver shielding plate beneath will lift with the board itself, don't panic. Just separate the adhesive and you're on your way.
FarmYard Gaming - crwdns2934203:0crwdne2934203:0
I'm currently wondering if a new SD card slot come with the adhesive foam or if I have to buy the adhesive foam separately. If I do have to buy the foam separately (which is most likely), then is it just normal isulating foam or if its electrically bonded to the metal shield through the foam
Jerhyn York - crwdns2934203:0crwdne2934203:0
do i have to desolder anything?
Ryan Massa - crwdns2934203:0crwdne2934203:0
no soldering necessary.
Matthew Chometa -
this is great. but how do you know if the card reader is good or bad?
Matthew Chometa - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 80
crwdns2936753:030crwdne2936753:0 297
crwdns2942667:0crwdne2942667:0 31,612
