Replacing the SD board in your 3DS may help resolve issues you're having loading and saving content.
crwdns2935267:0crwdne2935267:0Phillips #00 Screwdriver$5.49
Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
Pull the back cover up and away from the rest of the device to remove it.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
Lift the bottom edge of the lower case off the rest of the 3DS.
Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
Remove the lower case from the device.
Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
Insert the flat end of a spudger between the SD board and the motherboard.
Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
Once completely freed, lift the SD board straight off the motherboard.
crwdns2935229:022crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Where can i purchase the sd card board replacement part? Does amazon carry them?
You can usually find them on ebay to around $3 to $6 dollars (non oem and oem)
Is there a way to do this with the older 3ds xl version? I didn't see any screws holding the sd board in when I opened it up.
Would this work for my problem? My problem is that the SD Card won't stay in, it just pops back out. Would this method still work? I'm not that experienced or knowledgeable about fixing these sort of things, so I'm not sure if the spring is part of it or not, lol. Also, where could I buy an SD Card board replacement part for cheap in Canada?
Usually that is the locking mechanism, you can replace the SD card slot for around $6 or $3 if you buy the non oem part.
