  1. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
  7. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  8. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
  9. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
  10. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  11. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  12. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
  13. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  14. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
  15. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  16. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  17. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  18. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  19. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  20. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard assembly from the rest of the device.
  21. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the grey silicone cover off the back of the ABXY buttons.
  22. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the 3DS and orient it so that the back sides of the buttons are facing up.
    • Use your finger to push each button up and lift it out of the upper case.
    • Repeat this procedure for all four ABXY buttons.
    • Each button can only go into one slot in one orientation. Be sure that you are putting each button in the correct slot when reassembling your device.
crwdns2935229:029crwdne2935229:0
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
153 350 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2947412:016crwdne2947412:0
I completed it. And out of the whole process I only stripped one screw. :D Sooo I just unscrewed everything else and tore off the back. Anyway Mission complete!
dumppermen10 - crwdns2934203:0crwdne2934203:0
I got it apart and put it back together. The A and B still don't work however. I've never done anything to this extent before so it's probably my fault. But the problem may also be beyond my repair capabilities. I will likely try again. Also for some reason my sound doesn't work. I suspect it is not the actual speakers but something else instead. Oh well. I'll get a new XL and take better care of it!
leesr388 - crwdns2934203:0crwdne2934203:0
I've come to the conclusion that my a buttons contact has given out due to the fact I have to force it for a response maybe that is what happened to yours
Jordan Loader -
ok. so i managed the tear down as an experiment in seeing if i could do the process without destroying anything and i had complete success! now the problem is finding a replacement for the "select, home, and start" laminate buttons on the front of my 3ds ctr-001. can anyone provide a link? google and amazon are of no help.
William Scott - crwdns2934203:0crwdne2934203:0
I damaged the part of the socket, is there anything I can do to fix it?
Jaden Malcolm - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 200
crwdns2936753:030crwdne2936753:0 986
crwdns2942667:0crwdne2942667:0 124,135
