Nintendo 3DS 2015 Gamecard Reader Replacement
  1. Nintendo 3DS 2015 Gamecard Reader Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Gamecard Reader Replacement, SD Card Reader: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Gamecard Reader Replacement, Gamecard Reader: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement, Gamecard Reader: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  11. Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Gamecard Reader Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
Tyler Starr
crwdns2935283:010/06/16crwdne2935283:0
1,696 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-6, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 4-6, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S4G6
crwdns2935297:040crwdne2935297:0
Where can I find this replacement Part?
Sean Taylor - crwdns2934203:0crwdne2934203:0
Hello! Unfortunately replacement parts for this particular model are difficult to find. There seems to be some replacement parts for the XL; however, I don't think that they are the compatible with the regular 3ds. Additionally, slot replacements are sold widely; however, it would require difficult smd rework. Your best bet is to find a New 3ds 2015 that is being sold for parts on ebay that has a working gamecard reader and use that as a replacement.
Tyler Starr -
Does anyone know a replacement part link for this? I don't have the money for another one.
aiden owens - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 5,980
