Nintendo 3DS 2015 Circle Pad Replacement
  1. Nintendo 3DS 2015 Circle Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Circle Pad Replacement, SD Card Reader: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the joystick assembly near the top right corner of the motherboard.
    • Remove the two 8mm Phillips #00 screws from the back of the joystick.
    • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
  11. Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS 2015 Circle Pad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
    • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
    • Lift the joystick out of the device.
Michael
crwdns2935283:010/14/16crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-6, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 4-6, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S4G6
crwdns2935297:044crwdne2935297:0
Great, detailed tutorial. Was able to sucessfully unscrew my housing of the 3ds. I am currently fixing my circle pad.
Keyboard Smasher Gaming X - crwdns2934203:0crwdne2934203:0
Tutorial worked wonderfully, now have a fantastic feeling circle pad on the used N3DS I picked up.
Phantom Kirby - crwdns2934203:0crwdne2934203:0
Hi - can some steps be added to replace the actual joystick part of the circle pad? Thanks!
Daniel Griffin - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 133
crwdns2936753:030crwdne2936753:0 357
crwdns2942667:0crwdne2942667:0 11,752
