Nintendo 2DS Wi-Fi Card Replacement
crwdns2942287:0crwdne2942287:0This guide will help you replace the Wi-Fi Card in your original model Nintendo 2DS.
crwdns2944105:0crwdne2944105:0
Lift the battery cover up and pull it out.
Remove the 10 Phillips #00 screws.
Pull up the Wi-Fi card from the left side.
Use a spudger or your fingernail to carefully pull up on the right side of Wi-Fi card. This'll disconnect the Wi-Fi card.
Use a spudger or your fingernail to remove the cable from the Wi-Fi card.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
Where is the guide for the 2DS Zelda version? I just opened mine up, and there IS NOT a wifi module card anywhere to be seen?! Did they move it UNDER the motherboard? I can not find any guides to the green and brown Zelda 2DS. Mine won’t update or connect to anything now.
It is the same. If you cannot see a Wi-Fi card, there probably is no Wi-Fi card.
Ella -
The wifi chip linked is a "2878D-J27H02301" but the one shown in the picture for the 2DS is a "DWM-W082", will either work or do I need to get a DWM-W082?
