crwdns2959928:0crwdne2959928:0 ↓This guide for the Nintendo 2DS will teach you how to access the trigger buttons to remove them for cleaning or replacement.
Remove the two Phillips captive screws securing the upper rear panel.
Hinge the upper rear panel upwards and outwards to remove it.
Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Remove the ten Phillips screws attaching the rear panel.
Carefully pull the rear panel straight up from the device.
Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
Remove the cable from the connector
Pull the trigger button away from the device to remove it.
crwdns2935229:023crwdne2935229:0
Nice job! My right button was jammed for at least two years. Now I can finally demolish my friends in Mariokart.
Minecrafter Pig - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can’t seem to get the second set of screws to budge at all.
Zom baygal - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
