Nintendo 2DS Screen Replacement
  1. Nintendo 2DS Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 2DS Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
  4. Nintendo 2DS Screen Replacement, Rear Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten Phillips screws attaching the rear panel.
  5. Nintendo 2DS Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  6. Nintendo 2DS Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
  7. Nintendo 2DS Screen Replacement, Remove Side Panels: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 2DS Screen Replacement, Remove Side Panels: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
  8. Nintendo 2DS Screen Replacement, Unscrew Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
  9. Nintendo 2DS Screen Replacement, Remove Top Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Screen Replacement, Remove Top Panel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Screen Replacement, Remove Top Panel: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
  10. Nintendo 2DS Screen Replacement, Remove Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 2DS Screen Replacement, Remove Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
  11. Nintendo 2DS Screen Replacement, Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the ribbon cables connecting the screen to the motherboard have been disconnected before removing the screen from the front panel casing.
    • Grasp the screen firmly by a corner and lift it off of the front panel of the Nintendo 2DS.
    • There should be slight resistance due to the double-sided adhesive strip on the screen.
crwdns2935229:078crwdne2935229:0
Fina Beauchamp
crwdns2935283:001/12/15crwdne2935283:0
3,150 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 70-1, Forte Winter 2015 crwdns2935289:0Cal Poly, Team 70-1, Forte Winter 2015crwdne2935289:0
CPSU-FORTE-W15S70G1
crwdns2935297:035crwdne2935297:0
crwdns2947412:030crwdne2947412:0
Camera ribbon cable is very brittle, be careful.
Logan Pena - crwdns2934203:0crwdne2934203:0
Thank you so much, Fina! You have done a fantastic job explaining each step incredibly well! I very much appreciate all of your efforts into skillfully describing the process of disassembling the 2DS. I was able to understand your instructions and thus was able to make a lucky kiddo super happy! Thanks again!
-Skye
Skye Leah - crwdns2934203:0crwdne2934203:0
P.S. To those out there who don't have a super, ridiculously tiny (#000 screwdriver or 1.587 mm Phillips head) and don't want to have to purchase one just to complete this already daunting task, I found that using a screwdriver from a glasses repair kit worked PERFECTLY! :)
Once you've removed your screen, what are you supposed to do with it to clean and/or repair?
Danielle Chester - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 67
crwdns2936753:07crwdne2936753:0 450
crwdns2936753:030crwdne2936753:0 1,764
crwdns2942667:0crwdne2942667:0 164,984
