This is a guide for the removal of the back panel of the Nintendo 2DS. This guide will illustrate how to remove the screws attaching the back panel in order to access other parts of the Nintendo 2DS.
Remove the ten Phillips screws attaching the rear panel.
Carefully pull the rear panel straight up from the device.
Carefully flip the back panel over to locate the attached ribbon cable.
Remove the two Phillips screws attaching the ribbon cable to the rear panel.
crwdns2869486:0crwdne2869486:0
crwdns2878426:09crwdne2878426:0
crwdns2917036:02crwdne2917036:0
The two top screws on the backpanel I cannot get out, I used the same screwdriver I used for every other screw.
Please help!
For those two screws that are on the top cap aren’t supposed to come out, if the do come out it means you’ve broken those screws. Also after unscrewing that top it should just slide up.
