Nintendo 2DS Volume Slider Replacement
  1. Nintendo 2DS Volume Slider Replacement, Volume Slider: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement, Volume Slider: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement, Volume Slider: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the 2DS over so that the backside is facing upwards.
    • Identify the two Phillips #00 screws on the upper rear panel.
  2. Nintendo 2DS Volume Slider Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
    • The screws are captive and will not detach from the back panel or separate from the panel upon removal.
    • Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
    • Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
  3. Nintendo 2DS Volume Slider Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
  4. Nintendo 2DS Volume Slider Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the stylus out from the middle of the left edge of the device.
    • Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
    • Unlike the top rear panel, these screws come out, so be sure to keep them in a safe place.
  5. Nintendo 2DS Volume Slider Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
    • Don't yank or pull the back case off because the camera ribbon is attached to the motherboard and back case and may rip or damage the cable or camera itself.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
    • Use your spudger to gently slide the cable out of the connector.
    • Remove the back case.
  6. Nintendo 2DS Volume Slider Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the side that holds the volume slider off of the 2DS.
  7. Nintendo 2DS Volume Slider Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 2DS Volume Slider Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the volume slider from the sidebar housing.
S. Leng
crwdns2935283:010/24/22crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 240
crwdns2942667:0crwdne2942667:0 3,061
