This guide will demonstrate how to remove the plastic vent.
Unscrew the Phillips #0 11mm screws.
Unscrew the Torx Security #10 11mm screw.
Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
Pull the bottom covering off of the blender.
Unscrew the two Phillips #2 9mm screws.
Remove the plastic block.
Unscrew the four Phillips #2 11mm screws.
Remove the plastic covers.
Unscrew the three Phillips #2 9mm screws.
Pull the power cord through as shown to create slack.
Remove plastic casing by lifting upwards.
Follow the power plug cords to find the right plastic caps.
Squeeze the caps with pliers to loosen the grip.
Pull the plastic caps off the twisted wires.
Untwist the two wires from each other and pull the zip tie off.
Unscrew the 2 Phillips #2 9mm screws.
Grip the vent on either side and lift it straight in the upward direction.
