Ninja Ultima BL810 Power Plug Replacement
  1. Ninja Ultima BL810 Power Plug Replacement, Power Plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement, Power Plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement, Power Plug: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the Phillips #0 11mm screws.
    • Unscrew the Torx Security #10 11mm screw.
  2. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
    • Pull the bottom covering off of the blender.
  3. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two Phillips #2 9mm screws.
    • Remove the plastic block.
  4. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four Phillips #2 11mm screws.
    • Remove the plastic covers.
    • Removing the top cover and then rotating the bottom cover into the same orientation works best.
  5. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three Phillips #2 9mm screws.
    • This metal plate doesn't need to be completely removed, just adjusted to the side to continue working.
  6. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the power cord through as shown to create slack.
    • Remove plastic casing by lifting upwards.
  7. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the power plug cords to find the right plastic caps.
    • Squeeze the caps with pliers to loosen the grip.
    • Pull the plastic caps off the twisted wires.
  8. Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Ultima BL810 Power Plug Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Untwist the two wires from each other and pull the zip tie off.
Ryan James Gilroy
crwdns2935283:009/27/17crwdne2935283:0
364 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G4, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S9-G4, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S9G4
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 758
