Ninja Professional Blender BL660 Power Cord Replacement
  1. Ninja Professional Blender BL660 Power Cord Replacement, Blender Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement, Blender Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 Power Cord Replacement, Power Cord: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement, Power Cord: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check the connection between the power cord and the wires coming from the circuit board.
  7. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic caps on the wire connectors with your hands.
    • Ensure that the connections are not loose, corroded, or desoldered.
    • If the connections are desoldered, loose, or corroded, re-solder them using the iFixit soldering guide.
  8. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the connections in the preceding step are good, check the connection of the wires to the circuit board.
    • If the connections are loose or damaged, the blender may not be getting power.
  9. Ninja Professional Blender BL660 Power Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-solder the connections using the iFixit Soldering guide.
    • Make sure you check the correct solder points since the wires are routed differently.
Andre Obot
crwdns2935283:009/22/17crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
Central Washington University, Team S1-G1, Pengilly Fall 2017 crwdns2935289:0Central Washington University, Team S1-G1, Pengilly Fall 2017crwdne2935289:0
CWU-PENGILLY-F17S1G1
Hello,
I have a question. Do you know where can I buy the power cord for Ninja Blender. The model is BL 770. I have not found it anywhere. I also contacted Ninja Support by phone, but they don't sell this part of the Blender.
Denis Figueiredo - crwdns2934203:0crwdne2934203:0
Excellent pictures and directions! this made the repair easy
Donald Beers - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,409
