This guide will show you how to replace the drive socket on a Ninja Professional Blender BL660 (also known as the Ninja Professional 1100-Watt Blender).
The drive socket is also the part that connects the motor to the blades. If your blender turns on but the blades don’t spin, the socket might be worn out or broken. Replacing it can help your blender work like new again.
Before you begin this repair, make sure that your blender is off and unplugged.
Remove the blender jar and blades.
Turn the blender jar upside down and set it next to the base.
Use pliers or a wrench to unscrew the worn drive socket.
Align the replacement drive socket with the mount and hand-tighten.
Twist the blender jar back into its base.
