crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Carefully remove the second layer from the base. You will not need a screwdriver for this step.
Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
Carefully lift the base up from the rest of the blender.
Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
Check that the two red wires shown in the photos are properly soldered to the circuit board.
If they seem damaged, resolder the wires to the board.
If this doesn't solve the issue, proceed to step 6.
If the 2 wires in the previous step are connected, it's time to check the 2nd area.
Remove the plastic covers and check that the wires are soldered correctly.
