This will work as a prerequisite guide for all other guides. This helps us break down the device into the main base layer.
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Carefully remove the second layer from the base. You will not need a screwdriver for this step.
Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
Carefully lift the base up from the rest of the blender.
Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
Where can I buy a new board?
Mein yeh circuit board kharidna chahta hoon kha se milega
Same question here
crwdns2917034:0crwdne2917034:0
Hey Tommee where can I get a circuit board for the ninja bl 773.
