Ninja Mega Kitchen System BL770 Button Replacement
  1. Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Mega Kitchen System BL770 Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Mega Kitchen System BL770 Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
    Mein yeh circuit board kharidna chahta hoon kha se milega
    Pravjot Singh -
    Misma pregunta, donde compro esta placa?
    Antonio Paredes Vilchez - crwdns2934203:0crwdne2934203:0
    It's not a fix if you don't provide part numbers. Also stinks that you drew circles around the switches and covered up the solder point. I think the switches are 4 pin, but can't tell for sure...
    dale - crwdns2934203:0crwdne2934203:0
    Hi , where can I buy circuit board for my ninja bc770…
    Part# BL770-2(K01-BC-04-02)
    My name is Marino and have same issue
    Any help is appreciated.
    Thank you
    marino - crwdns2934203:0crwdne2934203:0
  5. Ninja Mega Kitchen System BL770 Button Replacement, Button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Mega Kitchen System BL770 Button Replacement, Button: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate which button you wish to replace.
    • On the back of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
    What changes required if we need to run this PCB on 220V? My PCB number BL770
    Ajay Dumasiya - crwdns2934203:0crwdne2934203:0
Tommee Walker
crwdns2935283:008/22/17crwdne2935283:0
850 crwdns2915208:0crwdne2915208:0
Arkansas State University, Team S1-G4, Chamberlain Fall 2017 crwdns2935289:0Arkansas State University, Team S1-G4, Chamberlain Fall 2017crwdne2935289:0
ARSU-CHAMBERLAIN-F17S1G4
Hi! I changed the “power button” and when I plugged it back, it went on without the press of the button, and it didn’t work. Think I may have made a lousy soldering job… :/
Luis - crwdns2934203:0crwdne2934203:0
Got a dead BL780. Pretty sure it’s the power switch as it’s been harder and harder to push to turn on. Going to attempt to replace on the board. I’m guessing that it’s a tactile momentary switch and that the board controls the power activation instead of the tactile switch being a push on/push off. Any insight would be appreciated.
Mark - crwdns2934203:0crwdne2934203:0
Where can I purchase the power button?
Mark
Cenek Picka - crwdns2934203:0crwdne2934203:0
Where can buy switch? What part number is the switch?
Mountain Buoy - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 2,393
