crwdns2959928:0crwdne2959928:0 ↓You will learn how to remove the motor from the base to check for frayed wires and/or loose screws.
Take out the three 15 mm Phillips #1 screws.
Remove the 15mm T10 screw.
Remove the gray base by lifting upwards and placing to the side.
Remove the three 15 mm Phillips #1 screws.
Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
Dear sir my ninga kitchen system 1100 (blender machine) motor rod is broken i need help to replace it where i can get the rod or repair shop near me thank you
Noman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
