Ninja Foodi SP101 Temperature Sensor Replacement
Griffin Peterson
crwdns2944107:0crwdnd2944107:0Griffin Petersoncrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 17, 2024crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
Reaching the desired temperature on your Ninja Foodi SP101 is an essential feature. The temperature sensor inside the device regulates temperature and the cooling fan. The inability to reach high temperatures on your Foodi may be due to a malfunctioning temperature sensor.
crwdns2944105:0crwdne2944105:0
  1. Ninja Foodi SP101 Temperature Sensor Replacement, Feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 Temperature Sensor Replacement, Feet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
  2. Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black lever bar.
  3. Ninja Foodi SP101 Temperature Sensor Replacement, Side Panels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
    I recommend using a PH2 bit here.
    Tzarial - crwdns2934203:0crwdne2934203:0
  4. Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device upside down and open the bottom panel.
    • Remove the 3 x philips #1 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
  5. Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
  6. Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 Temperature Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the handle and pull the side panel out.
    • Remove the handle side panel.
    There's a Torx screw inside the oven you need to remove as well...
    Richard Klingler - crwdns2934203:0crwdne2934203:0
  7. Ninja Foodi SP101 Temperature Sensor Replacement, Temperature Sensor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi SP101 Temperature Sensor Replacement, Temperature Sensor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The temperature sensor is found under the handle side panel.
    • The sensor is held down by a rivet. Here is a guide to removing rivets.
    It would be great to know how to replace the sensor at this point. I managed to make it this far on my own, but I'm unsure how to remove the sensor itself from the small metal plate it's clamped into.
    Andrew Jensen - crwdns2934203:0crwdne2934203:0
    Where do you purchase a new temp sensor?
    Charles Carlin - crwdns2934203:0crwdne2934203:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Griffin Peterson
crwdns2935283:001/30/24crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-4, McMurrin Spring 2024 crwdns2935289:0Utah Tech University, Team 1-4, McMurrin Spring 2024crwdne2935289:0
UTAHTECH-MCMURRIN-S24S1G4
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 1,188
