Ninja Foodi DZ401 Outer Casing Replacement
  1. Ninja Foodi DZ401 Outer Casing Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the air fryer so that the front is facing you and the top is accessible.
    • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
    • Place an opening pick on the left side of the corner to hold the ring away from the cover.
    • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
    • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
  2. Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
    • There are three openings on the front, one on each side, and four on the back of the unit.
    • The metal spudger may scratch or damage the cover if care is not taken.
  3. Ninja Foodi DZ401 Outer Casing Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the back of the air fryer is facing down and the base is facing you.
  4. Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 15 mm screws from the bottom of the air fryer using a Phillips #3 screwdriver.
    • Remove the power cord cover.
    • Remove the two 16.7 mm power cord bracket screws using a Phillips #1 screwdriver.
  5. Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the rear fan vents are accessible.
  6. Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 11.1 mm screws from each vent using a Phillips #1 screwdriver.
    • Remove both vents.
  7. Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Outer Casing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the outer casing up from the back.
    • Disconnect the front display cable from the motherboard.
    • Fully remove the outer casing.
A.J. Brain
crwdns2935283:010/02/24crwdne2935283:0
591 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Carnegie Fall 2024 crwdns2935289:0Eastern Washington University, Team 1-2, Carnegie Fall 2024crwdne2935289:0
EWU-CARNEGIE-F24S1G2
crwdns2942667:0crwdne2942667:0 164
