Ninja Foodi DZ401 Motherboard Replacement
  1. Ninja Foodi DZ401 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the air fryer so that the front is facing you and the top is accessible.
    • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
    • Place an opening pick on the left side of the corner to hold the ring away from the cover.
    • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
    • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
  2. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
    • There are three openings on the front, one on each side, and four on the back of the unit.
    • The metal spudger may scratch or damage the cover if care is not taken.
  3. Ninja Foodi DZ401 Motherboard Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the back of the air fryer is facing down and the base is facing you.
  4. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 15 mm screws from the bottom of the air fryer using a Phillips #3 screwdriver.
    • Remove the power cord cover.
    • Remove the two 16.7 mm power cord bracket screws using a Phillips #1 screwdriver.
  5. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the rear fan vents are accessible.
  6. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 11.1 mm screws from each vent using a Phillips #1 screwdriver.
    • Remove both vents.
  7. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the outer casing up from the back.
    • Disconnect the front display cable from the motherboard.
    • Fully remove the outer casing.
  8. Ninja Foodi DZ401 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the front is facing you and the top is accessible.
    Cuál es el número de parte de la motherboard DZ401
    MIGUEL VILLARREAL ZUÑIGA - crwdns2934203:0crwdne2934203:0
  9. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Extract the white, red, blue, and black wire bundles.
    • Using pliers, gently uncrimp and remove the plastic wire caps.
    • Carefully separate the wires.
    • The wires may be sharp. Use pliers for increased safety.
  10. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect black and yellow cords from the motherboard.
    • The black cord is labeled NTCR on the motherboard.
    • The yellow cord is labeled NTCL on the motherboard.
    • To disconnect, squeeze down the tab and pull the connector.
    • Disconnect both tab connectors.
    • The connectors are labeled FANL and FANR on the motherboard.
    • To disconnect, tightly grasp the connector and pull it up from the motherboard.
  11. Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi DZ401 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 13 mm mounting screws using a Phillips #1 screwdriver.
    • Carefully lift the motherboard up and remove it from the air fryer.
    • Only touch the outer edges of the motherboard to prevent component damage.
A.J. Brain
crwdns2935283:010/02/24crwdne2935283:0
591 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Carnegie Fall 2024 crwdns2935289:0Eastern Washington University, Team 1-2, Carnegie Fall 2024crwdne2935289:0
EWU-CARNEGIE-F24S1G2
Where can I buy the motherboard? Also, what are the part identification details I should use when searching online?
DANISH SHAIKH - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 215
