Ninja Foodi DZ401 Heating Element Replacement
  1. Ninja Foodi DZ401 Heating Element Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the air fryer so that the front is facing you and the top is accessible.
    • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
    • Place an opening pick on the left side of the corner to hold the ring away from the cover.
    • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
    • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
  2. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
    • There are three openings on the front, one on each side, and four on the back of the unit.
    • The metal spudger may scratch or damage the cover if care is not taken.
  3. Ninja Foodi DZ401 Heating Element Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the back of the air fryer is facing down and the base is facing you.
  4. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 15 mm screws from the bottom of the air fryer using a Phillips #3 screwdriver.
    • Remove the power cord cover.
    • Remove the two 16.7 mm power cord bracket screws using a Phillips #1 screwdriver.
  5. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the rear fan vents are accessible.
  6. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 11.1 mm screws from each vent using a Phillips #1 screwdriver.
    • Remove both vents.
  7. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the outer casing up from the back.
    • Disconnect the front display cable from the motherboard.
    • Fully remove the outer casing.
  8. Ninja Foodi DZ401 Heating Element Replacement, Heating Element: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the air fryer so that the front is facing you and the top is accessible.
  9. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the brown/orange wire bundle at the front of the air fryer and extract it.
    • Locate the white wire bundle at the rear of the air fryer and extract it.
    • Using pliers, uncrimp and remove the plastic wire caps.
    • Carefully separate the wires.
    • The wires may be sharp. Use pliers to increase safety.
  10. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white wire from the three guiding hooks.
  11. Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Foodi DZ401 Heating Element Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 10.9 mm screw from the front of the heating element using a Phillips #2 screwdriver.
    • Gently pull down the heating element from the front.
    • The element wires should come out of their respective holes.
    • Unhook the heating element from the rear hook.
A.J. Brain
crwdns2935283:010/02/24crwdne2935283:0
591 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Carnegie Fall 2024 crwdns2935289:0Eastern Washington University, Team 1-2, Carnegie Fall 2024crwdne2935289:0
EWU-CARNEGIE-F24S1G2
is it possible to start at step 11 to lower the heating coil a little bit to get inbehind the coil to really deep clean the top area? No tlooking to detach but clean.
Jacob Feht - crwdns2934203:0crwdne2934203:0
You are welcome to try that. If I remember correctly, it may be difficult to do so because of the awkward angle and wires attached. You may be able to lower it slightly but I am unable to confirm that. It is unfortunately a very frustrating device to take apart as you often have to disassemble the whole device, specifically the outer shell and lower base to get what you need.
Preston Dyess -
Where do you get the replacement heating element from? Is it an aftermarket part or OEM?
Alan Smithee - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 408
crwdns2942667:0crwdne2942667:0 2,249
