Over time, the silicone seal on your Ninja Creami bowl lid can become worn, stretched, or dirty, leading to leaks, poor blending performance, or difficulty locking the lid in place. Replacing the silicone seal is a quick and affordable way to restore proper function to your machine without having to replace the entire lid.
This guide will walk you through how to safely remove and replace the silicone seal in just a few minutes using no tools. The process is simple, but it’s important to handle the blade assembly with care to avoid injury.
Before starting:
- Make sure the machine is unplugged and the bowl is empty and clean.
- You may want to wash your hands or wear gloves to avoid introducing oils or debris to the new seal.
- If you're experiencing leaks, improper lid locking, or blending issues, this repair may solve your problem.
Press and hold the lid unlock button to disengage the locking mechanism.
While holding the button, lift the lid straight up to remove it from the bowl.
Flip the lid over to expose the underside.
Around the inside edge of the lid, identify the silicone seal sitting inside a circular groove.
Use your fingers to gently lift the edge of the silicone seal from the groove.
Slowly peel the seal out, working your way around the entire perimeter.
