Ninja Creami Rotating Shaft Replacement
  1. Ninja Creami Rotating Shaft Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Creami Rotating Shaft Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
    • Start at one edge and work your way around to avoid cracking the housing.
  2. Ninja Creami Rotating Shaft Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 13.6 mm Phillips screws from the perimeter of the outer cover.
    • Lift the black plastic cover straight up and off.
  3. Ninja Creami Rotating Shaft Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 12.2 mm Phillips screws from the black plastic cover.
  4. Ninja Creami Rotating Shaft Replacement, Daughterboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Creami Rotating Shaft Replacement, Daughterboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the daughterboard's motherboard connector.
    • Remove the daughter board.
  5. Ninja Creami Rotating Shaft Replacement, Rotating Shaft: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Creami Rotating Shaft Replacement, Rotating Shaft: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black connector from motherboard.
  6. Ninja Creami Rotating Shaft Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top of the gear housing while holding the bottom in place.
  7. Ninja Creami Rotating Shaft Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Creami Rotating Shaft Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the bottom of the gear housing above the shafts that it is on and pull out the rotating shaft.
Karlee B
crwdns2935283:002/17/25crwdne2935283:0
667 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-3, Sneed Spring 2025 crwdns2935289:0University of Memphis, Team 3-3, Sneed Spring 2025crwdne2935289:0
UM-SNEED-S25S3G3
Is there a replacement shaft anywhere online I could buy?
Daniel Jovel - crwdns2934203:0crwdne2934203:0
Also interested, where can I buy a rotating shaft?
Tozapid - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 102
