Ninja Coffee Bar CF086 Water Heating Element Replacement
  1. Ninja Coffee Bar CF086 Water Heating Element Replacement, Water Heating Element: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement, Water Heating Element: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the Ninja Coffee Bar is unplugged and that you have a dry, clean workspace for this task.
    • Remove the carafe and water reservoir and set them aside.
  2. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
  3. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the heating plate layer. This will expose the internal workings of the machine.
  4. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the water heating element in the interior of your coffee maker.
    • Unscrew the two indicated J1S1 screws at the base of the water heating element.
  5. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the remaining J1S1 screws that secure the water heating element to the interior of the device.
  6. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp and remove the clamp securing the tube that feeds into the base of the water heating element.
    • Detach the tube from the water heating element.
  7. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the coated wire that feeds into the side of the water heating element. Remove this wire.
  8. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two wires leading out from the water heating element that feed into crimp connectors.
    • Using side cutters, sever these wires near the crimp connectors.
    • Use the side cutters to cut the remaining wires that feed into the crimp connectors from the coffee machine.
  9. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze and remove the clamp that secures the main tube feeding into the water heating element. Remove that tube.
    • Remove the water heating element.
  10. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
    • Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
  11. Ninja Coffee Bar CF086 Water Heating Element Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare two crimp connectors by filling them with dielectric grease.
    • Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
    • Using a second crimp connector, repeat for the remaining pair of stripped wires.
    • Using the appropriate crimping tool, crimp the connectors.
To finish reassembling your device, follow steps 2-7 in reverse order.
David Ton
crwdns2935283:010/02/17crwdne2935283:0
630 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G5, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S1-G5, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S1G5
Where is the heating element available for sale.
ausbinp - crwdns2934203:0crwdne2934203:0
I need a element for a CM401 model, any help?. gene@wholedamarea.com
Lester Bouler - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,744
