This guide will show how to remove the heated plate from the coffee machine.
Face the machine bottom towards you.
Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
Remove the bottom board with moderate force.
Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
Remove the heated plate from the machine with easy glide.
Where do you get a replacement plate at?
