Ninja Coffee Bar CF080 Control Panel Replacement
  1. Ninja Coffee Bar CF080 Control Panel Replacement, Heated Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the heated plate from the machine with easy glide.
  8. Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 0.5cm screws with Phillips #2 screwdriver.
    • Some screws are harder to see due to how deep the holes are.
    • Recommend using Extender 4 with Phillips #2 screwdriver to help unscrew the screws within the deep holes of the machine.
  9. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 0.6cm with Phillips #2 screwdriver.
  10. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
    • There with be 1 blue, 1 black, 1 red and 2 white.
  11. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black board by maneuvering it through the cords.
  12. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
  13. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 0.6cm screws with Phillips #1 screwdriver.
    • They are in the black holes, 1 at the top and two at the bottom.
  14. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black board attached to the module.
  15. Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew four 1.2cm screws with Phillips #2 screwdriver.
  16. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the control panel from the control module.
  17. Ninja Coffee Bar CF080 Control Panel Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Left with the control module.
Jan Chen
crwdns2935283:009/11/17crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S1-G1, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S1-G1, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S1G1
This is great an all, but WHERE do you get the new control board?!? Without it this is worthless...
madmikey - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,224
