If your Coffee Bar fails to start up when plugged into a wall socket, then a problem with the power cable may be the cause of your issues. Follow this guide to learn how to replace the Ninja Coffee Bar’s power cable and breathe new life into your coffee maker. Warning: Be extremely careful when handling power supplies and make sure the unit is completely powered down.
Unscrew the eight 6mm #1 Phillips head screws off the bottom panel.
Lift lower panel up while passing the power cord through the opening.
Loosen two 6mm #1 Phillips head and remove clamp holding power cable.
Pull the power cable out exposing the two crimped ends.
Using a wire stripper/crimping tool, uncrimp wires.
