Ninja Coffee Bar® Single-Serve System Frother Replacement
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ninja Coffee Bar® Single-Serve System Frother Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
CJ Berg
crwdns2935283:011/05/18crwdne2935283:0
444 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 crwdns2935289:0UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018crwdne2935289:0
UMASSD-GULBRANDSEN-F18S5G4
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,710
