Nikon N2000 (F301) Communication Board Replacement
  1. Nikon N2000 (F301) Communication Board Replacement, Lens Mount: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
  3. Nikon N2000 (F301) Communication Board Replacement, Communication Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
    • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
  4. Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  5. Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  6. Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front case from the camera.
    • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
  7. Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  8. Nikon N2000 (F301) Communication Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the wires and remove them from the communication board.
    • Note: If you are unfamiliar with soldering techniques, click here for a guide.
    This guide also applies to the N301 The same camera for alternative markets.
    Be aware, removal of the lSO setting ring is required to enable top cover removal. Unscrew the film rewind knob and remove the circlip.
    In addition, there may be extraneous adhesive around the joint of the red stripe part to the top cover/body joint. Careful manipulation should release it.
    Ensure no camera controls are displaced as problems will arise during reassembly.
    RCDevon - crwdns2934203:0crwdne2934203:0
    I used this method to replace a broken aperture index ring, it's a bit tricky getting the spring back on, attaching both ends then easing the spring around the pulley, around 60 minutes of work. I also found the glue around the top front of the body a bit tricky too
    Graham - crwdns2934203:0crwdne2934203:0
Zachary Phillips
crwdns2935283:004/08/11crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-26, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 25-26, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S25G26
crwdns2947412:05crwdne2947412:0
Doesn't work for the 301, although it looks similar I can't find any way to remove the top or the front case
John Chapple - crwdns2934203:0crwdne2934203:0
The F301 and N2000 are identical, so the guide should work. In this guide the top case isn't removed, as the film rewind knob is preventing it from coming off completely, and instead just lifted with the bit of leeway the popped up rewind knob provides.
Miles Kosik -
Is there a way to remove the plasticzek top cover, as comment above says, the knobs prevents me from removing this part. My plastic cover is broken and I want to change it for a new one, is there a way?
Filip N - crwdns2934203:0crwdne2934203:0
The small metal post that was under the ring… where does this go? It moved as I lifted the ring and now for the life of me I can figure out where it’s meant to be… help. I opened it up because the black aperture ring was sticking and not springing back when I moved the aperture dial on the lens. My original problem is fixed but now I can’t reassemble my camera.
Daniel Jewesbury - crwdns2934203:0crwdne2934203:0
The only place I could imagine it fitting is inside the spring, just round from the screw at 2 o’clock… is that right?
Daniel Jewesbury -
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 6,777
