How to disassemble the back cover and replace a broken LCD. The outer window has been replaced and manufactured by me with plastic.
Here we have the Nikon L310 with the LCD and outer window broken. First of all, I start to remove the screws, but be careful, because they have different lenght.
First, we will remove the screws from the bottom side. These only 3. Remember the sizes!
Then, the 2 screws of the Right side
And finally, the screw above the USB port, on the Left side.
Now, its time to open the flash, and remove the screw that is allocated inside.
Remove the protector, and you will find a silver screw. Remove it.
Now, you can separate the rear plastic frame, carefully.
As you can see, the entire plastic frame cames out.
And here it is, the display!
Lift carefully the LCD module, and you will see that is connected by a FPC connector.
Release the tab, and unplug the flex cable.
Insert the new flex cable and install the LCD on its frame.
DONT forget to remove the protective film from the NEW LCD!!
Re-assembly all the parts, and put back the screws. The reparation is DONE! Here you can see the display fixed and the outer window replaced by methacrylate part made by myself ( I have one Dremel... )
crwdns2935229:09crwdne2935229:0
crwdns2944067:06crwdne2944067:0
Hi! I dropped my camera Nikon B500 and now the screen is black. The display shows and you can view picture plus menu. But you can not see when you want to take a picture. What do you think it is? And could I fix it myself? Thank you so much for helping. You can email me at hazel-04@hotmail.com
What size screwdrivers do I need for this job? And where would I get them?? Thanks.
How much is the screen if I wanna buy it?
How much is the screen for L310 coolpix I need 1
So everything went smoothly, except the part when I separated the rear frame, it was way too hard, all screws removed but I feel like I'm gonna break it if I try harder.
@ Sog T. Son - With you on this. I was just trying to clean some fungus from the screen and gave up at that point, lest I hear a dreadful crack! After all the screws have been removed, there must be some hidden truck to separate the rear cover which is not elucidated here. Anyway, off to the service centre we go.
