Nikon D90 Flash Bulb Replacement
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Open the Flash: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Open the Flash: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Removing the Bulb: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D90 Flash Bulb Replacement, Removing the Bulb: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
crwdns2935229:08crwdne2935229:0
jonothon cawley
crwdns2935283:010/20/14crwdne2935283:0
354 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-7, Duarte Fall 2014 crwdns2935289:0UMass Dartmouth, Team 1-7, Duarte Fall 2014crwdne2935289:0
UMASSD-DUARTE-F14S1G7
thanks for instruction…………really helpfull
hebi - crwdns2934203:0crwdne2934203:0
Hi guys do you know where to get this bulb?please help
Martin Mitter - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 7,685
