Nikon D80 Main Board Replacement
  1. Nikon D80 Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D80 Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D80 Main Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
    My D80 is displaying ERR no picture is saved when I click on the button, I can hear the shutter but no picture is saved. Firm ware is up to date. I was told maybe the ACU plastic screws are broken, where do you recommend buying parts? Your instructions are clear for removing the board. Thanks for that.
    Jose - crwdns2934203:0crwdne2934203:0
Sara Martin
crwdns2935283:010/09/17crwdne2935283:0
586 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Leahy Fall 2017 crwdns2935289:0USF Tampa, Team S1-G1, Leahy Fall 2017crwdne2935289:0
USFT-LEAHY-F17S1G1
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,629
