Nikon D80 Flash Assembly Replacement
  1. Nikon D80 Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D80 Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D80 Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the highlighted button to pop the flash up.
    • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
  2. Nikon D80 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
  3. Nikon D80 Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D80 Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pry open the cover.
    • Be advised, some plastic struts may snap off when you remove the cover.
  4. Nikon D80 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D80 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Use caution while using the hot soldering iron.
  5. Nikon D80 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the flash assembly from the casing.
    • The surface may still be hot, so grab it with caution.
Kevin Horwedel
crwdns2935283:010/09/17crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Leahy Fall 2017 crwdns2935289:0USF Tampa, Team S1-G1, Leahy Fall 2017crwdne2935289:0
USFT-LEAHY-F17S1G1
crwdns2942667:0crwdne2942667:0 2,562
