Use this guide to replace the mirror box and viewfinder.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
Remove three 6 mm J000 screws from under the battery cover.
Gently pull the bottom cover off of the camera body.
Remove the following screws from the port area:
Two 3.5 mm J000 screws.
One 6 mm J000 screw (right above ports).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Peel the rear rubber piece off with tweezers.
Remove one 4.25 mm J000 screw from behind the rear rubber piece.
Pull the eyepiece cover up to remove it.
Remove two 6 mm J000 screws from behind the eyepiece cover.
Open the SD card cover by pushing slightly down with your thumb and sliding up.
Remove four 6 mm J000 screws that secure the SD card cover.
Remove the following screws that secure the back case:
One 6 mm J000 screw.
One 3 mm J000 screw.
Disconnect the following two ribbon cables from the motherboard.
Remove the following screws securing the left motherboard shield:
One 2 mm J000 screw (on the bottom).
One 3.5 mm J000 screw (on the back).
Gently pry and lift the left motherboard shield off.
Remove one 3.5 mm J000 screw securing the right motherboard shield.
Gently lift the right motherboard shield off with the tip of a spudger.
Carefully disconnect the red connector with tweezers.
Remove four 3.5 mm J000 screws securing the motherboard.
Gently pull the port side cover away from the motherboard.
Remove four 6 mm J000 screws securing the tripod plate.
Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
Disconnect black and white speaker cable.
Remove three 6 mm J000 screws securing the image sensor.
Carefully lift the image sensor plate out of the camera.
Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
Remove two 5 mm J000 screws from under the flash.
Remove two 3 mm J000 screws securing the front cover.
Remove one 4 mm J000 screw from the front.
Remove one 8.5 mm J000 screw from the battery compartment.
Remove one 4 mm J000 screw securing the top case (under right strap hook).
Remove one 4 mm J000 screw securing the top case (under left strap hook).
Remove the sticker covering the diopter adjust screw.
Remove one 8.0 mm J000 screw.
Remove the Diopeter Adjust.
Remove the Black, Yellow, Green cable from the top case board.
Remove two 6.5 mm J000 screws securing the viewfinder.
Remove the viewfinder cover.
Remove one 3 mm J000 screw from the bottom left side of the camera.
Remove two 6 mm J000 screws from the left of the shutter.
Remove two 6.5 mm J000 screws from beneath the lens mount.
Remove two screws from just below and to the sides of the viewfinder.
Remove one 5 mm J000 screw from the top right of the camera.
Carefully peel back ribbon cable on the bottom left of camera.
Remove the left front ribbon cable from top right of circuit board.
Separate the shutter assembly from the camera body.
Pull out ribbon cable from circuit asembly near front left of device.
Disconnect ribbon cable at the top right of camera.
Disconnect ribbon cable at top right of camera.
Disconnected ribbon cable at rear right of viewfinder.
Remove the viewfinder from the mirror box assembly.
crwdns2935229:05crwdne2935229:0
now I know why my camera failed,, the motor overheated
sir francis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
