Nikon D70 Memory Compression Board Replacement
    1. Nikon D70 Memory Compression Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your finger tip to pull the battery release tab toward the center of the D70.
      • Open the battery door and rotate it away from the bottom cover.
    2. Nikon D70 Memory Compression Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the battery out of the D70.
      • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
    1. Nikon D70 Memory Compression Board Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following eight screws securing the bottom cover to the D70:
      • Six 5.8 mm Phillips screws
      • One 10.7 mm Phillips screws
      • One 8.2 mm Phillips screws
    2. Nikon D70 Memory Compression Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D70 Memory Compression Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the bottom cover to separate it from the body of the D70.
      • Remove the bottom cover from the D70.
    1. Nikon D70 Memory Compression Board Replacement, Memory Compression Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
      • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
      • Be sure you are prying up the retaining flap, not the socket.
      • Pull the ribbon cable straight out of its socket.
    2. Nikon D70 Memory Compression Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
      • It is not necessary to completely remove this piece of tape.
    3. Nikon D70 Memory Compression Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon D70 Memory Compression Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon D70 Memory Compression Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
      • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
      • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
    4. Nikon D70 Memory Compression Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure not to lose the small iron core around the DC-In ribbon cable.
    5. Nikon D70 Memory Compression Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
    6. Nikon D70 Memory Compression Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
    7. Nikon D70 Memory Compression Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D70 Memory Compression Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the memory compression board by its edges at the position shown in the first picture.
      • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 24,493
