If you get some CHA - errors on your Camera, it is likely time to replace the CF slot. The part number of the Nikon D70 CF slot is 1F998-181.
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
Pull the LCD board ribbon cable out of its socket.
Carefully pull the sides of the rear cover away from the body of the D70.
Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
Remove the two Phillips screws securing the holder of the CF Card Slot.
Peel of the Foil securing the Flexcable.
Use Tweezers to open the locking on the ribbon cable socket.
Pull the ribbon cable out of its socket.
Carefully fold the Pull the ribbon cable towards the CF Slot
Remove the two Phillips screws to separate the Holder from the Slot.
crwdns2935229:022crwdne2935229:0
crwdns2944067:05crwdne2944067:0
Mine has a pin broken off. Where do I get a replacement?
Hello,
Thanks to your help, I was able to replace it easily.
Many Thanks from France
How do i change out the board with the pins…… second hand cam someone bent alot of pins
I can order board or can i order the whole cf ?
You can find them on ebay real easy. both full assemblies and just the board with the pins
