Need to clean out every last speck of dust? Scratched your sensor filter? Swapping out the filter for a custom modification? This guide can help.
Unscrew the eight Phillips #00 screws on the back panel:
Two 2.5x6mm screws above the screen.
One 3x6mm screw on the upper part of each side (two total; right side shown).
One 3x7.5mm screw on the lower part of each side (two total).
Two 3x4.5mm screws on the bottom.
Pull the back panel up, then tilt it back. There will be two cables still holding it on.
Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
Disconnect the six ribbon cables by releasing the clips and pulling the cables out.
Pry off the gold-plated connector with an opening tool, spudger, tweezers, or a fingernail.
Disconnect a seventh ribbon cable in the lower-right corner.
Desolder the five wires attached to the back of the board.
Remove the five silver Phillips #00 4x4mm screws.
Flip up the motherboard.
Remove the white cable connector by pulling it out of its socket with a spudger or fingernails.
Remove the L-shaped ribbon cable from both of its connectors.
Remove the three silver 5x5mm screws.
Flip the sensor board out.
Remove the four silver 3.5x3.5mm screws securing the dust cover.
Pull the cover straight up to remove it.
To remove the sensor filter, pull back the rubber gasket to expose the edge. Use a spudger or opening tool to carefully pry out the filter.
crwdns2917034:0crwdne2917034:0
Excelente guía, solo que debo cambiar las cortinillas y creo que es por el frente de la cámara
