Need to replace a cracked screen, or just clean underneath the screen protector? This guide shows how to access the LCD monitor.
Flip out the screen. There are four Philips #00 screws securing the black plastic case.
Detail of a 2x2.5mm side screw.
Detail of the two 3x4mm bottom screws.
Using plastic opening tools, pop the back cover off. Start from the bottom of the case, by the hinge.
Pull straight up to remove the front panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Slide the screen assembly forward and off of the hinge mount.
With a spudger, opening tool, or fingernail, pop up the clip on the wide ribbon cable.
Using tweezers, slide the dark brown portion of the connector down. This will release the lower ribbon cable.
Slide both cables out of their connectors.
Pry the circuit board off of the adhesive on the back of the screen. Use a spudger or opening tool.
Remove the LCD screen.
where i can buy lcd it self. paste link if can. tqsm.
crwdns2935229:013crwdne2935229:0
Great guide. Very thorough and the images were most helpful. Worked for me! THANKS.
When I open my D5000 i found out that the Blue and Orange wire on the board was disconnected and had no Idea where it goes (until i saw in the picture then I figured it out). But Overall I managed to assesmble the LCD and was feeling great. Although everytime I change the LCD view upsidedown, it doesnt respond to it unlike putting the view left or right (that works..i wonder why?). Thanks for the guide
Hi, I also have the blue wire disconnected. Despite this, my screen appears fully functional. Anyone knows what this wire is supposed to do..?
Thanks, the guide is perfect!
Menu buttons are not working or all buttons. I can take pictures,LV button is not working. How can I repair? Thank you very much!!!
the pin lock to the wide ribbon cable is brittle already, is there another way to reattach the cable?
My screen is bad is not too clear I can see but very bad I think is the screen how do I replace
