Nikon D40 Viewfinder Replacement
crwdns2869540:0crwdne2869540:0: 4,3 k
3
31
121
4 323
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0
This guide will help to you access your viewfinder in your Nikon D40 and replace the viewfinder.
    1. Nikon D40 Viewfinder Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
    2. Nikon D40 Viewfinder Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D40 Viewfinder Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
    3. Nikon D40 Viewfinder Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    4. Nikon D40 Viewfinder Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
    1. Nikon D40 Viewfinder Replacement, Viewfinder: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
      • Be careful not to pull too hard on the ribbon cables.
    2. Nikon D40 Viewfinder Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly push the upper body up until you see the frame of the viewfinder
      • Be careful while pulling the top camera body.
    3. Nikon D40 Viewfinder Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to keep the upper body separate from the printed circuit board.
      • Wiggle the plastic eyepiece out of the frame. This may require some force.
    4. Nikon D40 Viewfinder Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the viewfinder with the plastic opening tool.
      • Do not push too hard while using the opening tool.
    5. Nikon D40 Viewfinder Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The viewfinder has been removed!
Amy Chen
crwdns2935283:001/23/14crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-19, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-19, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G19
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 121
crwdns2959996:0crwdne2959996:0 4,323
