Nikon D40 Flash Pin Replacement
  1. Nikon D40 Flash Pin Replacement, Flash Pin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the camera and remove the battery.
  2. Nikon D40 Flash Pin Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the flash open using the plastic opening tool.
  3. Nikon D40 Flash Pin Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #0 3.0 mm screws from the front of the flash compartment using the small Phillips Head screwdriver.
  4. Nikon D40 Flash Pin Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D40 Flash Pin Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the back plastic of the flash compartment using the plastic opening tool.
    • When it is time to reassemble the flash module, a certain amount of force and precise alignment will be required.
  5. Nikon D40 Flash Pin Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D40 Flash Pin Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the left of the camera you will see a metal spring.
    • Unscrew the Phillips #0 3.0 mm screw holding the spring in place, using the small Phillips Head screwdriver.
  6. Nikon D40 Flash Pin Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove metal spring and replace with new spring.
Lindsey Chase
crwdns2935283:001/21/14crwdne2935283:0
227 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-19, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-19, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G19
crwdns2942667:0crwdne2942667:0 4,062
