Nikon D3100 LCD Screen Replacement
  1. Nikon D3100 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver for all of the screws.
    • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
  2. Nikon D3100 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D3100 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
    • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
    For my camera, the two bottom screws were 3mm, the upper left is 4 or 5mm, and the upper right (behind the label) is much larger.
    No problem, and they’re unambiguous
    Rob Cuthbertson - crwdns2934203:0crwdne2934203:0
  3. Nikon D3100 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the rubber grip on the right side of the camera using a spudger.
    • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
    • Remove two of the 5mm screws under the rubber grip.
  4. Nikon D3100 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two of the 4mm screws on the left side of the camera.
    You also have to remove the rubber cover for these ports, or you won’t be able to do the next step. Pull gently directly away from the camera body until the strap comes out. Re-insertion is as simple - push gently, or guide with a small flat-head screwdriver
  5. Nikon D3100 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon D3100 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
    • Be careful not to pull the panel out too fast or the ribbon may be damaged.
    • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
    • Separate the back panel from the main body of the camera.
  6. Nikon D3100 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
    • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
  7. Nikon D3100 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape covering the ribbons. Be careful not to break the tape.
  8. Nikon D3100 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
  9. Nikon D3100 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old LCD screen from metal plate.
crwdns2935229:08crwdne2935229:0
Jet Mejia
crwdns2935283:009/26/16crwdne2935283:0
662 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-1, Eyestone Fall 2016 crwdns2935289:0USF Tampa, Team 14-1, Eyestone Fall 2016crwdne2935289:0
USFT-EYESTONE-F16S14G1
crwdns2947412:05crwdne2947412:0
Very helpful guide, so happy to have a non-cracked screen again!
now, where can i buy this replacement screen here in the Philippines?
leumas_erbutco - crwdns2934203:0crwdne2934203:0
does anyone have the part number for the replacement screen?
Lee Caterson - crwdns2934203:0crwdne2934203:0
Très bien ce document, seulement l'écran LCD pour Nikon D3100 semble introuvable, et épuisé !!! Avez-vous une adresse valable pour commander?
gtre - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 124
crwdns2942667:0crwdne2942667:0 14,333
