Nikon Coolpix S9700 Back Panel Replacement
  1. Nikon Coolpix S9700 Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement, Back Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S9700 Back Panel Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
Matt Staubus
crwdns2935283:010/05/16crwdne2935283:0
849 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Lacy Fall 2016 crwdns2935289:0USF Tampa, Team 9-5, Lacy Fall 2016crwdne2935289:0
USFT-LACY-F16S9G5
crwdns2942667:0crwdne2942667:0 1,353
