If you need to replace a damaged case with a new case of the Nikon Coolpix S6500 you can do it with the help of this guide. For this guide, you will need a Phillips PH000 Screwdriver to remove the screws. Store the screws safely. Open the case carefully. Before beginning, make sure to power off the camera completely and disconnect it from any external power source.
            Remove all eight 3mm screws by using the Phillips #1 screwdriver. One is behind the flap covering the HDMI and charging ports.
Was soll dieser Pfusch? Da fehlt doch die Hälfte.
