This guide shows how to replace a broken display
            Place the camera facing upwards.
            Press down on the battery cover and slide towards the front face of the camera.
            Rotate the orange battery clip in the camera to release the battery.
            Locate the eight outer PH 2mm screws on the device.
            Using the PH00 screwdriver remove all of the screws from the camera.
            Using a plastic opening tool, gently pry off the front and rear plates.
            Be patient with this step, do not force the clips holding the plates together.
            Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
            Disconnect the connectors using a plastic spudger.
            You may now remove the internal panel of the buttons.
            Remove the clasp from the ribbon cable using the plastic spudger.
            You may now remove the display.
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
