Before replacing your battery cover door for your Nikon Coolpix S630 you would need to read how to remove back panel and front panel. Removing both back and front panels are necessary to starting this guide.
            The battery compartment is located on the bottom of the camera.
            Place your thumb on the battery door.
            Slide the door away from the camera in the direction the arrow points to.
            Slide the yellow tab towards the back of the camera.
            The battery should pop out.
            Remove the battery.
            Press the memory card down into the camera.
            The memory card should pop out.
            Remove the memory card.
            Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
            Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
            Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
            Carefully remove the back casing from the camera.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
            Gently pull the ribbon from the logic board with tweezers.
            With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
            Locate a small, rectangular flap above the battery cover door.
            Push the small, rectangular flap back through the hole.
            Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
            Locate the battery cover door.
            Press and slide the cover door open.
            Locate the small rod that is securing the door in place
            Using a tweezers, grab the rod and slowly pull the rod out
            Place battery cover door back into place with spring between the insertion holes.
            Using a tweezers, gently slide the rod through the insertion holes and through the spring.
I am stuck on step 8. How am I supposed to hold it down and pull the front cover off. I can only get the corner up where the battery goes.
