Nikon Coolpix S5300 Button Panel Replacement
  1. Nikon Coolpix S5300 Button Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 Button Panel Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 Button Panel Replacement, Button Panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S5300 Button Panel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
Waleed Chakir
crwdns2935283:003/04/16crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 crwdns2935289:0UMass Dartmouth, Team 6-1, Bhusal Spring 2016crwdne2935289:0
UMASSD-BHUSAL-S16S6G1
crwdns2942667:0crwdne2942667:0 286
