Nikon Coolpix S3100 Camera Lens Replacement
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lens is now separated.
crwdns2935229:011crwdne2935229:0
Jorge
crwdns2935283:003/11/15crwdne2935283:0
1,170 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 2-4, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 2-4, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S2G4
crwdns2935297:013crwdne2935297:0
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - crwdns2934203:0crwdne2934203:0
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - crwdns2934203:0crwdne2934203:0
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - crwdns2934203:0crwdne2934203:0
I have same issue it shutter half opens and doesnt open correctly
shailendra - crwdns2934203:0crwdne2934203:0
my LCD screen is stuck on white after after i did this :(
andrew welles - crwdns2934203:0crwdne2934203:0
After I put the lens in place, the camera works and the front lens retracts, but the image is blurry and it immediately says that the lens has an error and the camera turns off. what should I do?
last mountaineer - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 4,941
