If you shutter lens does not seem to operate, these guides will help you find the problem.
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
Remove the two screws.
Gently pull up to detach the frame. (picture 2)
Remove 2-2.10mm screws using a #000 Phillips screwdriver.
Gently pull the orange board to the right.
Gently pull to the left to release from ZIF connector.
Remove 4-2.10mm screws using a #000 Phillips screwdriver.
Remove 3-2.12mm screws using #000 Phillips screwdriver.
Use a nylon or metal spudger to release the lens.
Repeat step 4 to the opposite side of the lens.
crwdns2935229:011crwdne2935229:0
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
Nikon coolpix s3100 lens mocking place help my
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
I have same issue it shutter half opens and doesnt open correctly
my LCD screen is stuck on white after after i did this :(
After I put the lens in place, the camera works and the front lens retracts, but the image is blurry and it immediately says that the lens has an error and the camera turns off. what should I do?
