This guide will show the reader how to remove the LCD Screen in case it needs to be replaced.
Remove the two 2.8 mm screws on the left side of the camera.
Remove the four 2.8 mm screws on the right side of the camera.
Remove the three 4.1 mm screws on the bottom of the camera.
Gently lift the rear cover from the camera.
Gently lift the screen out of its place.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
Slowly pull the screen from the camera.
Where did you obtain the replacement LCD screen? I have two of the Coolpix's with broken LCD screens. I found your page looking for the dreaded "lens error", which the pulling on the lens idea helped me fix and now I would like to replace the cracked LCD screen in that camera. I had never thought it economically feasible. Thanks.
Got my replacement LCD from eBay seller for very reasonable price.
The guide has you removing a couple, maybe 3 screws from the front side case, which I believe could have been left in place, but otherwise it is a good repair guide. If I had known how easy and cheap this repair was going to be, I would have done it over a year ago. I thought that I was going to have to find a repair shop (even looked and they wanted $90 per hour just for labor and did not have a price for the part(s). Glad I found the LCD on eBay and did it myself. Only took 5 minutes and IIRC, the LCD screen was less than $20 including shipping.
did you ever fix your camera
